Best Intake and Carbs
RE: Best Intake and Carbs
hotrod thats a little overkill for 300hp, but it prally work if tuned right, and leaves alot of rome for improvements.
79 youll be fine with a 600 or 650 an any of the aftermarket intake should flow an easy 300hp, I would look into the holley and edelbrock intale kits that include a matched cam ive seen these kits for under 300.
The stock carb from an '85 is a 600 cfm I believe. My current motor is basically a carbed '88 motor with a few minor mods and I run a 650 holley which works great
Yes I should elaborate more I guess. A 650 would be fine I have alot of work into my Holley. But also I wouldnt be scared to bolt it onto a 351 either. Like vfast said its depends on what else is on that motor.
I would use an Edelbrock Performer RPM intake and a 600 cfm carb. I know a few people who have used this setup and it works good. A 600 more than enough carb. What kind of trans. are you running?
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
