Boost gauge and gauge pod
Old 06-30-2007, 08:08 PM
92hatchLX
92hatchLX's Avatar
Default Boost gauge and gauge pod
So my next step with this blower is finding a nice but affordable boost gauge. I'm not looking for anything fancy, most likely just a mechanical gauge that comes with everything that I need to get it installed. This is what I'm looking at, does anyone have any feed back on that guageand any technical info on how this is installed? I'm guessing that your linesjust tee into one of your larger vacuum lines such as your brake booster?
Gauge (The sending unit is included):
http://store.summitracing.com/partde...?part=ATM-4904
A-pillar gauge pod:
http://store.summitracing.com/partde...part=ATM-10100
92hatchLX is offline
Old 07-01-2007, 12:00 AM
luckythirteen13
luckythirteen13's Avatar
Default RE: Boost gauge and gauge pod
first off, you dont need a boost gauge that reads 35psi. i would buy a boost/vac gauge. one that reads between 20in/hg and 20psi. you just get a t fitting and splice into any vac line. the brake booster line is way to big, a small one will work better.
the pillar pod is nice. i used to have one on my car till i put my roll cage in. the pod interfered with the cage so i had to take it off
luckythirteen13 is offline
Old 07-01-2007, 01:14 AM
samseed101
samseed101's Avatar
ORIGINAL: luckythirteen13
+1. That is EXACTLY what I have. if you're going to spend money on boost gauge, then you might as well get a boost / vacuum gauge since 99.9% of the time, a boost gauge would read 0. It's a great tool to have for diagnostics as well.
Also as stated above, why get a gauge that reads to 35 when you won't be pushing more than 12 or so PSI? That just makes it harder to read your exact level.
samseed101 is offline
Old 07-01-2007, 01:24 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
My set up. And I don't wanna hear any shyt about 30 psi on the gauge, I bought it used!!! The pod, both gauges, 45 bucks. Yeah, that was a steal, I mean deal!!!
PRO50SC is offline
Old 07-01-2007, 01:35 AM
AdderMk2
Banned
AdderMk2's Avatar
lucky... you can get cage mount gauge cps ya know
AdderMk2 is offline
Old 07-01-2007, 01:38 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
Check out this pillar pod....it is full length....This is what I got....and it looks real good!
http://www.latemodelrestoration.com/...1&comp=LRS
They have a three pod one too...
CantStopTheFox... is offline
Old 07-01-2007, 01:39 AM
90mustang5.8
I ♥ Acer
90mustang5.8's Avatar
ORIGINAL: PRO50SC
yet you bought a CLOCK gauge[8D]
90mustang5.8 is offline
Old 07-01-2007, 01:40 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
And?
PRO50SC is offline
Old 07-01-2007, 02:11 AM
90mustang5.8
I ♥ Acer
Old 07-01-2007, 02:16 AM
stang8689
stang8689's Avatar
I also got mine of the pillar, easy to see
stang8689 is offline
Quick Reply: Boost gauge and gauge pod
