What size Injectors Do I use ?
RE: What size Injectors Do I use ?
well first you didn't say what psi your running and if you use a fmu?
I would use a 24# injector with a fmu or a 30# with no fmu if using around 5-7 psi 36 if above that over 12 use atleat 42 with no fmu
How much boost are you planning on?
I would say 30#
Here is a useful link to help determine the size you need: http://www.mustangworks.com/cgi-bin/analyzer.cgi
Scroll down the page to the fuel system analysis and plug in the numbers.
I would say 30#
