boggin at 5k plus rpms
i have a question its kind of complicated.
i just picked up a 86' gt and when i hit my second gear to 5k plus it seems to make the car bog and jump my rpms in a certain pattern verry irregular what would you guys think the problem would be?
RE: boggin at 5k plus rpms
347, trickflow heads, cam, and intake, 75mm tb, 75mm egr plate, cai, 30# injectors with calibrated mass air, AFPR tuned to 32-33.5 psi at the dyno shop. it started bogging on me like a week after i got it tuned. my distributor is cracked a little bit on the bottom, I dont know if that affects it in any way. I have msd 6A with a rev limiter
I pm'd you a couple of days ago asking for some advice on your set up. How are you making 402 rwph??? the best pass that I got it at the shopp was 340 with shorties, I have longtubes now So i should be making a little more. rev limiter is set at 6k. 5200 rpm I believe
Whiskey
15
12-04-2010 09:48 AM
