3g conversion bracketry work
Old 07-03-2007, 12:16 AM
mattdel
mattdel's Avatar
Default 3g conversion bracketry work
ok i got tomorrow off, so i wanna do the 3g conversion...
first off, does anyone have a better detailed/pictured explanation of the process, besides what I can currently find? I wanna make sure I do this right the first time, and the tech link on here isn't the greatest.
secondly, if you used a dremel on the alt bracket, which bit did you use?
mattdel is offline
Old 07-03-2007, 12:24 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: 3g conversion bracketry work
Matt, I took my cut off wheel and made cuts in the bracket about a 1/4" apart and then took a screw driver and broke out the lil pieces. Very easy to do and works out great. If you mock up the new alt, you'll be able to see where exactly it will hit and make your marks.
PRO50SC is offline
Old 07-03-2007, 12:27 AM
mattdel
mattdel's Avatar
i suppose I could go to work tomorrow and grab my die grinder. do you suggest a straight or 90degree ?
did you use a brand new cutoff wheel, 3", or an older one that is smaller?
mattdel is offline
Old 07-03-2007, 12:37 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
LOL I really don't remember how warn out the wheel was but you can use a new one. I didn't use a die grinder at all. After the alt is in place, you can't see the "handy" work.
PRO50SC is offline
Old 07-03-2007, 12:42 AM
mattdel
mattdel's Avatar
oh you used a cutoff wheel with a dremel?
mattdel is offline
Old 07-03-2007, 12:52 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
No, just the cut off wheel.
************************** <<< Bracket
^^^^^^ slits in the bracket
************************** <<< end results after the trimming of the bracket
PRO50SC is offline
Old 07-03-2007, 12:57 AM
mattdel
mattdel's Avatar
i'm sure i'll figure it out.
can you explain the wiring modifications necesary?
mattdel is offline
Old 07-03-2007, 01:02 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
The oe plug, cut the 2 black orange wires, put those together and mount on the power feed of the new alt. the small one left, you need the plug from a 3g, splice it on the white green or w/e color that one is and plug it into the new alt. The regulator harness is the same and plugs right in. then you can run the 6 gauge wire w/ the 150 amp in line fuse from the bat side of the soleniod to the power feed on the back of the alt.
PRO50SC is offline
Old 07-03-2007, 01:05 AM
mattdel
mattdel's Avatar
sounds easy enough. thanks.
mattdel is offline
Old 07-03-2007, 01:09 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
It is, very easy job to do. I've done like 3 or 4, last one only took about 30 min. Far from rocket science. G/L!
PRO50SC is offline
Quick Reply: 3g conversion bracketry work
