spark plug wire melt - MustangForums.com
Old 07-03-2007, 01:49 AM
crocop
Default spark plug wire melt
i have mac shortie equal length headers. if you stand in front of the car the plug wire that is second from the rear of the block on the passenger side is touching the header becase there is not much room for it and is starting to melt. what can i do/use to prevent this?
crocop is offline
Old 07-03-2007, 01:51 AM
mattdel
mattdel's Avatar
Default RE: spark plug wire melt
a new wire set that fits snugly, and then when you route the wires, point them so they dont hit, and tie them up with wireties or spark plug wire holders, and they wont move.
Ford Racing 9mm wires work very nicely, and cost under $50 everywhere
mattdel is offline
Old 07-03-2007, 02:00 AM
ALMOST STOCK
ALMOST STOCK's Avatar
MSD makes a bendable boots so that you can miss the header, is another option.
ALMOST STOCK is offline
Old 07-03-2007, 02:10 AM
crocop
the boots on my spark plugs are perfect for every cylinder except the one. the boots them selves are very small and fit very snuggley on the spark plugs. i have taylor wires. for the one problem wire, the wire CANNOT be moved so that it clears the headers it just sits nicely on top which is a problem. can i get some sort of material to seperate the two from touching? i have tried other wires such as msd and the boots were way to long they were pretty much touching every tube on the header. what do you think?
crocop is offline
Old 07-03-2007, 02:17 AM
LTnone
There are some metal loom 'covers' you can buy, fits over that part of the plug and prevents the burning
LTnone is offline
Old 07-03-2007, 02:20 AM
crocop
what if i covered that on part of the headers with that heat rap that i see on some cars, its like a white material?
crocop is offline
Old 07-03-2007, 02:22 AM
LTnone
Heat wrap is bad stuff, I'd stay away from it. Looks ugly for one, but it tends to trap water and rust the headers out over time
LTnone is offline
jwog666
01-07-2018 08:16 AM
Omgitsa88Stang
10-05-2015 08:33 AM
Matt's 95 Stang
10-05-2015 08:16 AM
Dathan
10-05-2015 06:52 AM
lmurf60
09-24-2015 11:07 PM
Quick Reply: spark plug wire melt
Featured Sponsors
© 2018 MH Sub I, LLC dba Internet Brands
