Just got my car back!
Well I just got my car back from my install guy. Well car is pretty sweet. I have not really got on it yet but I will a little tomorrow! Here is what got installed:
TrickFlow Heads/Track Heat Intake
Anderson B41 Cam
42lb Injectors
255 pump + Vortech Pump
Anderson Power Pipe
SCT 2400 MAF Meter
UPR Big Mouth Filter.
Smog Pump Delete
Car made 445hp/450torque at the dyno. Vortech with the stock pulley made 14 lbs of boost
I will add pics tomorrow!
Anderson B41 Cam
42lb Injectors
Anderson Power Pipe
SCT 2400 MAF Meter
Smog Pump Delete
RE: Just got my car back!
ORIGINAL: Glasersil
Anderson B41 Cam
42lb Injectors
Anderson Power Pipe
SCT 2400 MAF Meter
Smog Pump Delete
Anderson B41 Cam
42lb Injectors
Anderson Power Pipe
SCT 2400 MAF Meter
Smog Pump Delete
ORIGINAL: aode06
thats 500 hp at the flywheel, this will scare you. be VERY carefull.
ORIGINAL: Glasersil
Anderson B41 Cam
42lb Injectors
Anderson Power Pipe
SCT 2400 MAF Meter
Smog Pump Delete
Anderson B41 Cam
42lb Injectors
Anderson Power Pipe
SCT 2400 MAF Meter
Smog Pump Delete
ORIGINAL: Glasersil
Anderson B41 Cam
42lb Injectors
Anderson Power Pipe
SCT 2400 MAF Meter
Smog Pump Delete
Anderson B41 Cam
42lb Injectors
Anderson Power Pipe
SCT 2400 MAF Meter
Smog Pump Delete
Is Correction Factor on the Sheet SAE or STD?
Are you running Cats?
What was total timing on that 445 run?
Thanks
