93 5.0 with a 90 harness?
Im pretty sure im going with a carb setup BUT i have a question. I have a 90 4cyl notch. Do i absolutely need a 90 gt harness for the wiring OR can i get any GT harness and use it? The engine is out of a 93 5.0. What would happen if i used a 88gt harness?
RE: 93 5.0 with a 90 harness?
That wouldn't be very good, as the two use completely different air metering systems. With a '93 motor, you'd be able to use any harness from '89-'93. If you're in CA and can find an '88 that uses a Mass Air system instead of Speed Density, then that would work too
ORIGINAL: LTnone
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
