Mac Throttle Body??
Mac Throttle Body??
I baught a Mac 70mm TB and EGR spacer, I heard by some people that the Mac TB is crappy and that the gaskets make the car idle bad. Is this true? What are the best throttle bodies out there? Is mac one of them?
Mac Throttle Body??
there all about the same I thing as far a finish accufab is no.1....the people who you talked to most likey we a tight *** and reused the gaskets...Mac makes a nice T/B ..just make sure all sufaces are clean. make sure your intake opening wiLL match or is bigger than that 70T/B
Mac Throttle Body??
well...t/bisnt something thats a big power adder so its not like one is going to give u 20hp and one's gunna give u 2...they're pretty much all jus gunna help a little bit for air flow...as far as quality, BBK makes pretty good t/b...but no one is gunna stand out way more than other i dont believe. hope this helps <IMG src=smileys/smiley14.gif border="0"></P>
Mac Throttle Body??
that where your wrong ..it could be 20+if that where the restriction is </P>
ex:</P>
I was using a 65mm on my s/c could only get around 7-8 psi</P>
went to a 75mm T/B and now get 13-14 psi..about 50-70 horse powerno other changes...</P>
but in all fairness when putting a 70mm on a stock engine it will lose hp so you were on the right track with your 2 hp gain</P><edited><editID>vfast</editID><editDate>37868.4917939815</editDate></edited>
Mac Throttle Body??
I have a good amount of work done to my car but im also thinking about the future when i get a new motor and really hook it up. Will I lose power by putting on a 70mm TB when i have a trick flow street heat intake,fuel preassure reg, bbk cold air kit, pulleys, electric fan, BBK equal lenth headers, O/R H-pipe? Will i still lose power
