HOW GOOD ARE THESE HEADS?
MY GOAL IS TO BUILD A 300+HP ENGINE. THE HEADSI HAVE ARE E7TE. ARE THESE HEADSABLE TOPRODUCE THE POWER IM LOOKING FOR? THEY DO HAVE FRPP ALUMN. 1.6 ROCKERS...AND WHAT CAM DO YOU RECOMMEND FOR A DD CAR BUT IF I WANT TO GO TO THE TRACK I CAN AND WANT BE EMBARRASED-IM WANTING SOMETHING TO GIVE ME A ROUGH IDLE BUT TOP ENDPOWER ----THANKS FOR ANY INFO
RE: HOW GOOD ARE THESE HEADS?
wow....where to start. im sure you dont want a rough idle, i think your looking for a lope in you idle. get a mild cam, b303, tfs-1 soemthing like that. if you wanna dish out the money get a custom grind. e7's suck. if your on a budget go gt40's otherwise get a good set of aluminums. i cant believe you WANT to be embarrased. seems kind of strange, i usualy like to look good in my car. lol. get some gears. cheap and good mod
man you want a nice set of 1.90 valve heads..small cam something like a 490-512 which will have 0 issues..I would install a nice small NX kit using maybe a 75 shot for those race runs ONLY!
Here is a link to head flow charts. It is for every make head, and every manuf.
Where are you at GA. I live in middle ga.
http://users.erols.com/srweiss/tablehdc.htm
Maybe someone should make that link a sticky. It also shows flow on ported heads also, unless there is already a sticky with flow charts.
Keith
http://s194.photobucket.com/albums/z112/keithswearingen/?action=view¤t=c3a71cc9.pbw
Keith
i dislike "p" heads
i agree w/ the b-cam
i agree on 1993 cobra heads, they are the real gt-40 iron heads f3zz casting i think
typically find them for $500 tops, do minor port work concentrate on the exhaust
squirt 75 on it
it takes heads,cam,and intake to make 300 true hp w/out nitrous, and 300 true hp will turn mid 12s in the 1/4
squirt 75 on it
stop using caps.
e7te's are stock heads. they barely support the 225hp stock later fulie cars made.
exploer heads will support 300hp, not much more but they are much better than what you have now. they do have some fittment issues with headers as the spark plugs are not in the traditional location. some shortys work and most long tubes will work. there are also p specific headers that can be purchased.
a rough idle will give you top end power at the expence of low end power. good heads, good induction, and a mild cam will make 300 pretty easy.
you mentioned you didnt want to get embarresed at the track, you will want to make alot more than 300hp. make sure you get some gears and some drag radials at the very least. that with 300hp will get you in the high 12-low 14 second range.
