how nasty are solid motormounts?
RE: how nasty are solid motormounts?
poly is the way to go....the solid benifit is you don't lose as much hp transfer as the rubber one kind cushions the twist....using the solid one's on the street will in time show with stress on the chassis,trans case,so rattles will start occurings,etc
ORIGINAL: 2 kwik
ORIGINAL: Shelty
I though vert mounts set the engine up an inch higher... or is it an inch lower?
11-10-2015 11:39 AM
