Alrighty, turn signal question....
I have a 1990 GT and my turn signal isn't working. The brights work, as do the wipers and hazard lights, I doubt it's the switch, so what do you think it could be?
RE: Alrighty, turn signal question....
Damn man, you just spent...what 100$+ bucks on the multifunction switch for it not tofix the problem?I just had this same problem last night. I lost my turn signals, but the 4ways worked..was gettin ready to pick up a new switch when I looked under the column and saw one of the connectors not plugged in all the way. It usually is a bad connection before a bad switch
ORIGINAL: dickweed
Also, in my 1989 GT, there are two blinker relays. One for the hazards, which is on the fuse panel, and another above the driver's left knee.
ORIGINAL: WhiteFoxGT
