whats a good car to get a bigger throttle body off of?
a few people say that 86 has the smallest throttlebody and that i sould get one off a 87 or newer fox, im wondering if i can get one off a lincoln or other non mustang car at the boneyard?im going to today so let me know if u know
RE: whats a good car to get a bigger throttle body off of?
http://www.tmossporting.com/tabid/1671/Default.aspx
I cut and welded mine...didn't want to cut up the stock one.
ORIGINAL: 86GT 93LX
I HAVE A SPEED DENSITY CAR DOES THAT COME INTO play at all? i wanna get a t.b. of a crown vic since theres tons of those at the boneyard.
is a crown vic ok yo use, it faces the other way under the hood, so is the t.b link 180 off in the wrong direction? and is a non ho one going to be bigger on a 87- whatever 5.0?
what to look for at the boneyard addermk2? there wont be any mustangs with 5.0s and unlikely any explorers, lota vans and big ford cars maybe a v8 tird, some 4.6 stuff too
ORIGINAL: 86GT 93LX
do you know the size of one on a 86? yeah i saw the ones on crown vics and they are pretty small and backwards anyways, is a 87 really bigger than a 86? is the explorer the same as a 93 cobras or a 94-95 cobra? no v8 explorers at the bone yard as i figured
ORIGINAL: raven_ghostwolf
I had one from the 87 Crown Vic I got my build-up block from it was only 55 mm I belive thru it away along with the smaller bore intake. I just mesured the stock one from my 87 5.0 HO it mesured 59.9mm so 60mm. The one on my car now is from an Explorer I didn't mesure it but it matches bore size with my BBK 70mm EGR spacer. The Explorer TB I had to swap out the linkage arm witht the factory one from my 60mm so it would work correctly.
ORIGINAL: 86GT 93LX
ok the most reliable info I could find is as follows;
Speed Density
1986 58mm TB flow capacity 541 cfm 86 has a different upper than 87 - 93
1987/88 60mm TB flow capacity 580 cfm
MAF
1988/93 60mm TB flow capacity 580 cfm MAF 55mm
93 cobra 65mm TB flow capacity 638 cfm MAF 70mm
Non-HO 5.0 Full size(Crown Victoria, Marquis, Thunderbird & Lincoln) 50mm TB flow capacity 338 cfm
Speed Density
MAF
DO U KNOW WHATS ON THE EXPLORES? I HEARD that 97 explores are good for heads and intake gt40p heads ? i think i want a 65 mm tb for sure... but if my intake is crap it wont do me much good!
Speed Density
MAF
Speed Density
MAF
