Smoke at WOT
Smoke at WOT
Smoke at WOT
94 GT 5.0l
less than 1000miles on motor
moly rings
vortech s/c 8lbs
new twisted wedge heads
cometic mls headgaskets
140psi on all cylinders dry test
no smoke on startup or cruising
is this normal at wot? what would be the cause of this?
94 GT 5.0l
moly rings
vortech s/c 8lbs
RE: Smoke at WOT
What color smoke? white, blue or black? If your engine and head gasket is fine and the smoke is not white, then I'd either guess that it's black (running rich at WOT) or it's blue and it's oil. To take it one step further... If it's blue and again, if your engine is fine, then I suspect you may have blown the oil dipstick out under boost and it sprayed some oil onto the headers. That's very common.
RE: Smoke at WOT
ORIGINAL: HACKGT350
motor might not be broken in yet you gotta give it more than 1000 miles before you go WOT on a new motor
RE: Smoke at WOT
ORIGINAL: HACKGT350
lol yeah im a youngin and i am old school when it comes to breaking in motors
RE: Smoke at WOT
ORIGINAL: samseed101
i had similar problems on mine... i dont even have my oil dipstick in cuz it doesnt fit in very well... so that could be my problem too
ORIGINAL: HACKGT350
