Fuel pressure is the same with vacum on and wiht it off???
Old 07-10-2007, 06:32 PM
Jared_blown5.0
Jared_blown5.0's Avatar
Default Fuel pressure is the same with vacum on and wiht it off???
Just like the title says. My fuel pressure would increase with vacum off before the blower was installed. Now when I try to adjust fuel pressure it is the same on and off. What could it be.... Could I have put the vacum T for the bypass valve in the wrong spot causing no difference in fuel pressure with vacum on or off?
Jared_blown5.0 is offline
Old 07-10-2007, 07:59 PM
samseed101
samseed101's Avatar
Default RE: Fuel pressure is the same with vacum on and wiht it off???
Where are you checking the fuel pressure? How do you have the regulator hooked up? it should be a very short line that goes straight from the regulator to the elbow in the intake (I'm assuming this is on your 94.)
samseed101 is offline
Old 07-10-2007, 08:07 PM
Jared_blown5.0
i have the regulator vaum line going t'ed 2 times.... It goes from elbow to a t that leads to the boost gauge and regualtor, and then another t that goes to the boost timing retard ignigtion box.... I am taking it Thats is a no no? And yes this is on my 94 samseed.
Old 07-10-2007, 08:21 PM
samseed101
samseed101's Avatar
That's a lof of T's, lol. I guess technically it shouldn't be a problem, but I try to avoid that. I try to keep that line as short as possible to avoid problems. When you pull it off with the engine running, can you at least feel the vacuum on that line leading to the regulator? If you have a spare piece of vacuum line ( $0.99 per foot at a parts store), just temporarily run a direct line between the elbow and the regulator and see if the pressure changes. If there is a change, then you know where hte problem is. If it doesn't change, then it sounds like a bad regulator to me.
Old 07-10-2007, 09:24 PM
creekrat
creekrat's Avatar
+1 sam! Make sure you have vac at the regulator!
creekrat is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel pressure is the same with vacum on and wiht it off???
