Next Mods
Next Mods
so far ive got full headers and exhaust and 3.73 gears (not installed yet) my next mods i would ike to get
- underdrive pullies
- intake manifold
- throttle body
- cold air intake
- and a MAF system
questin is can some 1 tell me what all parts and components i will need and if possible weres best place to buy them from for
- intake manifold like will i need diff injectors? or anything
- throttle body what size 65mm or 70?
- and for the Mass air flow can i just go get a MAF off a 95 mustang and will it just bolt right up?
if any one can help me id really appreciate it!
- intake manifold
- throttle body
- cold air intake
- and a MAF system
RE: Next Mods
depends on your goals, if staying with stock heads or gt-40 irons I would go with the cobra and a 65mm throttle body. Your best bang for buck is a cam swap. Mass air will have to be 89-93 not 95, they are pretty cheap on Ebay go for 73-76mm
RE: Next Mods
C&L Performance makes aCAI than includes a 76mm MAF housing. I think I have seen them on the Teaxas Hot Rod website for $210ish? It would take care of 2 of your furture mods in a single system designed to work together. I have the C&L 76mm system on my SN95 5.0, and felt a nice improve over the K&N filter w/o silerncer in the factory intake tract. As far as a T.B I was thinking about a 65mm for my car with stock manifold, but with a aftermarket mainfold a 70mm would prob. match the new intake opening better.
RE: Next Mods
http://www.texashotrods.com/StoreFro...amp;i=18277449
i think this is that intake/maf ur talking about blk5.0. it says 86-93 tho... did you have anyproblems with it bolting up? alot of stuff says only 86-93 but i always wonder if it will fit the sn95 5.0'ssince we have pretty much the same engine.
RE: Next Mods
I think the original poster has a fox, and intake manifold opening are in diff location on SN95's, so kits are not the same. I got my kit off of partshopper.com $250. Worked great in my situation, those stock MAF look restrictive as hell. C&L Performance has a dyno sheet for a 95 with the kit intalled on their website.It was preety easy to install. Aboubt 30 mins to remove old/install new. I wan't even at home when I did it, it's strightfoward.
