NEED some help here
NEED some help here
Its been a while since ive been on here, i just pulled my engine today and ahve it all taken apart ready for the HCI + supercharger. I have some questions about what i need to put this back together.
First thing i bought the heads used months ago, i dont have any torque specs for aluminum trickflow track heat heads...i need them where can i get these at...anyone on here...possibly summit or calling trickflow.
I need a gasket set for the engine, which one should i get since its gonna have an hci + 8-10lbs from PN-2000.
Head bolts? which ones will i need...
I need 3/8s roller rockers for the heads, do i need push rods and roller lifters as well? if so what set would be best to get at summit tommorow
And i bought the 76mm maf meter, do i just use the stock sensor on this then?
lastly i have the polished cobra intake manifold...is there anything to plug the where the egr sensor is...or do i need to run that, because im gonna ditch the smog pump so i do i need the egr one?
Any help would be great, i hope to get answers to night as im giong to summit tommorow to pick up what i need.
RE: NEED some help here
You'll need the fel pro ones for aluminum heads 1011-1 I believe if the heads are o-ringed which I would have done since your running a boosted application if not already done?? then you'll need to get gaskets from fel pro for o-ringed heads. as far as all the trick flow specific questions go to their website and download the instructions and the egr you can buy block off plates through summit I believe then once the car runs have it properly tuned.
ORIGINAL: hurricanes0688
call summit, they have great customer service.
I need a gasket set for the engine, which one should i get since its gonna have an hci + 8-10lbs from PN-2000. i cant help you here
Head bolts? which ones will i need... ARP bolts, http://store.summitracing.com/partde...t=ARP-154-3601
rods: http://store.summitracing.com/partde...t=TFS-21406700
yes get roller lifters, get a new timing chain also
the MAF meter has a sensor in it made for a specific injector size.
lastly i have the polished cobra intake manifold...is there anything to plug the where the egr sensor is...or do i need to run that, because im gonna ditch the smog pump so i do i need the egr one? nope, take a flat fiece of plate the shape of the egr flange and drill the holes, put the gasket between the two and bolt the plate down.
