347 parts list
347 parts list
hey guys, some of you already know I'm in the process of a stroker buildup. This is a list of parts I'm considering, tell me what you think so far! btw, stock block balanced and blueprinted w/ probe srs forged dished pistons.
Heads= AFR 185's w/ 58cc combustion chamber
Cam= xfi 236hr-14 ( lift:.579"/.579", duration: 286*/300*, 236*/248* @.050"
Intake= Holley systemax 2
comp cams pro magnum roller rockers, frpp hardened pushrods 5/16" dia. 6.272 length (i will check valve to piston clearance before i buy, just listing these as a package purchase) 70mm pro products tb, 75mm pro m mas, frpp 30# injectors, aeromotive afpr, and a walbro 255 lph pump.
What do you think? btw, 9.30 c/r w/58cc comb. chamber.
RE: 347 parts list
Hey Jasper, there are no plans for any other power adder, and what kid of cam specs would you recommend? I'm not sure what you mean by pull rpm's out, does that refer to the cam spec?
RE: 347 parts list
if there are no other plans and you plan on staying N/A i would try to bump the Compression Ratio and then have a custom ground cam set up where you can you make horsepower into the 7k rpm range.
other than that sounds like a nice set up
RE: 347 parts list
I have the XFI cam and have been happy with it.
You will want to get compression up to 10.5 though
make sure you upgrade the springs on the AFR's for the cam too.
You will want a 75-80mm TB and 90mm MAF too.
347 needs LOTS of air at upper rpms.
measure for pushrods before buying.
my 357ci engine with AFR 185's, CompCams XFI cam, 1 3/4 LT's
and running 10.2 compression made 475hp at 6,000 rpm on engine dyno
have fun
have fun
09-17-2015 07:57 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
