Weird Revv........
#21
RE: Weird Revv........
That makes sense because my brakes suck i have hardly any powerbrakes. there is a ton of pressure at the pedal and i was thinking that the booster was going bad and now that you said something it makes total sense.. i will check it and probably end up replacing it and see what happens.. thanks for all your help guys.. i will let you know what happens..
ORIGINAL: mustang8719
Another thing you might want to check fro as far as a vaccum leak is make sure the brake booster isn't going bad.One other sign that might help you know would be to look between the master cylinder and booster and make sure you aren't leaking brake fluid.When the master cylinders rear seal goes bad it leaks fluid into the booster and messes up the diaphram in the booster causing a vaccum leak.
#22
i had the same problem after i put a 70mm throttle body on my car the throttle sensor on the top of the throttle body i to it off and drilled the holes out that mount it to tb and set it back on car but dont turn it just set it on loose and look to see that the holes line up on the tb with the sensor if so then put screws back on it and go if not make the holes bigger BUT DONT MAKE THEM SO BIG U F UP THE SENSOR. i dont know if it really worked or not because i had intake off to and put a new gasket on so try gasket first and then try the thing with sensor. i heard it work from another form so it might work who knows but it fixed my problem.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
mungodrums
09-28-2015 10:54 PM
