Help! Noise coming from clutch?
RE: Help! Noise coming from clutch?
its not like a loud squeak....it sounds like the pedal is rubbing against something and it makes a scratchy rubbing sound...nothing high pitched or loud. when the clutch engages it grabs just the same...it doesnt do it everytime. for some reason i think its temp related. sometimes its as smooth as ever when i push it down.
ORIGINAL: ChevelleStang
The scratchiness could be the bearing retainer too(gettin grooves)
I am still thinking it is the TOB, but just make totally sure and don't just throw money at your car. I say this because it is difficult to diagnose symptoms on the internet. Is there any way you can make a sound clip of the noise it is making?
It is more than likely the release(throw out) bearing. I had the same problem. The clutch quadrant on the fox body cars is not made for the driving style of most mustang owners. The teeth that ratchet, skip when you drop the clutch until you have no free play left and a stiff clutch pedal. If you have a fox, you should get a firewall clutch adjuster. I have one with a centerforce dual friction and stock cable and I have no complaints. Idon't have to adjust it very often. The easiest way to adjust it is pull of the dust sheild on thetranny and take the cable off the fork and pump the pedal and pull on the cable until you have slack again and then adjust your adjuster accordingly.
u know ur prob sounds almost exactly like mine......previous owner did clutch except with mine when my foot is off the clutch it will make the noise but ive heard several different things like pilot, throwout and something else a slow mechanic told me
