Help! Noise coming from clutch?
When I press the clutch in my 1992 lx it makes a weird squeaky noise. The clutch engages and works fine but i dont understand the noise. Also, when I press it it has a scratchy, rubbing feel. Does anybody know about or had this happen to them? I think maybe the cable or some part of the clutch, maybe the bearing, or something may need lube?
RE: Help! Noise coming from clutch?
Is there any way to contact the previous owner and find that info out. There are a lot of cheap and lazy people who will only do a job half ***. I hate when people do that because then you may have to pull the tranny and replace the tob and get the flywheel turned possible.
it could mess the clutch up, but you will more than likely not be going anywhere if the tob does go out, you can't get the pressure plate moving without the tob.
taking the t-5 out is not that difficult, and you could save your self about 3-500 dollars doing it your self. you and a friend with a little bit of mechanical knowledge could easily tackle the job. If you had to take it some where, and it is definately giving you trouble, take it to a transimission shop. You may want to take it to a few shops and find out what they think before you shell out that kind of cash.
How bad and what type of squeak is it making. Noise like a brake squeaking or something else?
