damn vacumm leaks
whats the best way to check for vacum leaks?? and what is the most common place for me to find one, i checked all the lines,but it still runs like crap, its gotten to the point where if I keep a very steady throttle i can feel my car almost jerking forward a little like the fuel mixture is too lean, i was told that b/c of a vacumm leak the computer tries to compensate for the leak by adding more fuel and that is what is causing my car to almost studder or jump a little bit, especially if going up a big hill..and the check engine light goes on,any suggestions?? I also heard that you can spray carb/choke cleaner around the intake manifold and if the rpms jump that means there is a leak is around the intake.. is that correct, is it carb cleaner that i should use or something else? I appreciate any help, thanks, oh also how would i know if I have a bad injector.
RE: damn vacumm leaks
smoke machine all the way!!! if you don't have access to one try a can of carb cleaner and spray around all fittings, hoses and gasketed intake areas listen for a rise in idle.. BTW if you have a vaccum leak the miss will be present at idle and as you raise the rpm's the miss usually goes away or is greatly reduced if you still have a dead miss at or above 2000 rpm's it's probably not a vaccum leak. in that case you'll need to check ignition components or internal integrity of the motor ie....compression test if all ignition componets check out okay
I hear of this product where they introduce a smoke soultion under pressure into the crankcase of your engine. Where ever you have a vac leak, voila, smoke comes rolling out. Sounded pretty trick to me, but it also sounded like a product that the backyard mechanic probably wouldn't be easily affording.
i've heard of using a cheap propane torch too. open it a bit and move it over the vacuum lines and car will rev when you find a vacuum leak.
smoke machine FTW!!! best tool ever made!
cool cool, i have a propane torch, dont have a smoke machine tho, canti use anything that makes smoke tho? ie cigarette or something
nope. sorry dude the cig wont cut it. just use the propane, it'll work great. like it was said before, just put it around any air can be "ingested" into to motor and listen for the rpm to raise.
ORIGINAL: greenstreak9205 nope. sorry dude the cig wont cut it. just use the propane, it'll work great. like it was said before, just put it around any air can be "ingested" into to motor and listen for the rpm to raise. It may sound stupid, but you know damn well that at least one person would have read this in the future and used a lit torch. |
unfortunately that is very true [&:] good call sam
you guys all suck a$$ , who was the retard that said to use a torch??? i just melted all my vac lines and my sparkplug wires too !!!! this is BS if i knew who you were.....i would sue you this sux |
