Throttle response is a bit laggy...
Will a mass air intake or something similiar fix this? I really can't get over 4,000 RPM's even when I floor it. ok maybe 5 but it doesn't get to redline :\
RE: Throttle response is a bit laggy...
ORIGINAL: mudvayne1
The same problem is going on with my car. I changed plugs, wires, coil, and fuel filter and I still can't figure it out.
I'm pretty sure it's the stock intake, but that's just a guess.
I'm not the best at motors...my area of expertise is car stereos....what should I do to check it? (preferably anything that wont cost anything, and wont result or possibly result in damaging the motor)
Also, is this going to damage the motor in anyway? If the only negative effect is being unable to redline, then I'm fine with that, but if it's causing more damage then that I need to fix it.
Maybe your fuel pump is going, the pump may not be able to deliver the needed fuel to the motor when you push past a certain rpm. How is the fuel filter, has it been changed.
you also might have a loose baffle in your fuel tank.....but usually you'll have a different string of issue other than not being able to rev past 4k.
also i've heard about ignition coil going out and having rev issues.....this could also be but again there are a whole different string of problems.
if all your experiancingis not being able to rev past 4k and everything else performs as it should, i suspect valve float.
get new heads
get new heads
