HCI Finished - Car doesn't want to idle stalling out*Updated Pg2*
UDPATE: Trying to get the timing right.. think it was off even though it would originally start and idle, but now it won't.... Please read posts down below...
So the car starts good and just won't idle. If I hold the gas at 1 grand, the car sounds good and is fine but once I let off shuts off. Timing should be all good, any other suggestions? Thanks! |
RE: HCI Finished - Car doesn't want to idle stalling out
Possible vacuum leak or that's what my problem was anyway.
to radical of a cam for the puter to know wtf is going on? maybe it needs to relearn?
that's what i was thinking and checked all lines... What are the key areas that will cause that...
The car won't start unless I give it gas and hold the idle steady... I just went to take the car out for the first time and got a little unlucky... I'm not sure what to do... The car was idling fine and then after a couple starts it decided it didn't want to start anymore... |
ORIGINAL: my77stang to radical of a cam for the puter to know wtf is going on? maybe it needs to relearn? |
The E303 is not a radical cam at all, so that's not your problem. It is probably a vacuum leak, or the timing isn't right, or the fuel pressure needs to be adjusted.
Distributor off by 1 tooth.
ORIGINAL: samseed101 Distributor off by 1 tooth. My only thing that makes me disagree though is how come it idled good all last night for a minute and then again this morning and again this morning? I moved the car about 10 ft shut it off... Went to turn it on and then it wanted me to give it gas. |
When I set the timing the crank was set to 0 degrees and I tried to line up the dizzy but the cut in the block wasn't even with the mark on the dizzy...
You have a timing light? Adjust your idle with your TB screw and see if you can keep it going, check timing.
