Angcobra 5.0 Block Broke?
Well, for all of those that have been wondering how long my stock 5.0 block could hold more than 800 HP at the crank, it seems just over 2 years maybe the answer.
I have not torn it down yet but it has all the classic symptoms, loss of power, running rough, water leaking from under the intake, and low to 0 oil pressure.
Maybe at least, all of my internals and heads are okay since it is still running. Now I might just move all of that over to a real block and turn it up to see what this combo could really do.
Even if it is broke, I have gotten a lot of use from the stock block. Over the last 2 years, this block has provided more than 250 power passes either on the track or the dyno. It has powered my Mustang to many 6.3 @110 and ~10 sec @132 passes. It has provided many shows at the dyno as on lookers watched it's progress from 500 RWHP to almost 700 RWHP the day it gave up.
All in all, I should not be able to complain about the service this block gave me.
I will update this post later when I start the tear down.
[IMG]local://upfiles/10436/3D095F8853E24D66907CA5B6916E695F.jpg[/IMG]
[IMG]local://upfiles/10436/9DD7913230E840168BA3E9D6D4A69F2C.jpg[/IMG]
[IMG]local://upfiles/10436/FE29DE6AD5314CFFB3F90D863ACB22BC.jpg[/IMG]
[IMG]local://upfiles/10436/3ECD8316FCFF4D46A09016F9368DBE04.jpg[/IMG]
[IMG]local://upfiles/10436/F1D54F1196FF4F6889C486BE9609A93A.jpg[/IMG]
RE: Angcobra 5.0 Block Broke?
ORIGINAL: my77stang
heres a early (C8, supposed to be stonger) block that had approx 400-425 @ flywheel
ya just never know when they are gonna go POP [8D]
ORIGINAL: greenstreak9205
guess you cant really be incredibly mad considering that you knew that it was gonna happen
ORIGINAL: Jasperstang308
i am surprised it held up for as long as did.
what do you plan on buying as a replacement
Not sure what I will build as a replacement. Might be kind of hard to go with a different combo when this one was so strong.
Some o f the local guys would like me to build the same combo but with a turbo instead and really turn the boost up.
