I installed BBK equals laast night and now my steering rack is rubing against the header. I've heard of this before just curious if there is a remedy to this, or if they will evetually dent themselves.
The fix for this needs to be a tech sticky since it's asked so often. Like stated above, replace the mounts or shim the drivers side to cure the problem.
put washers between the motor mount and the mounting surface, that will get u enough clearance. mine took 2 washers, do it to each side so its not uneven.
