HELP 86 STANG WON'T RUN - MustangForums.com
Old 07-16-2007, 12:41 PM
great 8
Default HELP 86 STANG WON'T RUN
Ok for the past 4 months my 86 stang 5.0 has not been running right. It was sputter randomly at high and low rpm . It will also hesitate when i hit the throttle this will happen randomly as well.It also it dont want to hold idle it well cut off if i let just sit and idle for like 5 mins. So what i did is i put a New Fuel filter,Fuel pump,Fuel relay switch,EGR valve,Fuel regulater,TPS,Distbuter with brand tfi and Coil.I just but the Fuel regulater on yesterday and sit it to 40 psi with vac off.I also put the new distbuter on to set the timing at 10*.Now its worst then before It'll start but when i hit the gas it just act lik it wants to just die out i barely made home last nite.Could I have added to much fuelwith 40psi with vac off ? When the key is off the gauge reads its at 30psi iono if thats normal or wat?Also It backfires look hellI cant get past10mph over that then itll cut off. Also it'll randomly drop in rpms like fromif im crusing or just leting it idle it'll drop and dam near cut off.So yea kno dats alot but CAN SUM1 HELP PLEASE HELP !!!!
great 8 is offline
Old 07-16-2007, 01:13 PM
86 5.0L
86 5.0L's Avatar
Default RE: HELP 86 STANG WON'T RUN
any smoke?
86 5.0L is offline
Old 07-16-2007, 01:40 PM
great 8
no
great 8 is offline
Old 07-16-2007, 02:21 PM
86GT 93LX
86GT 93LX's Avatar
the idle air control IAC should be cleaned or removed also egr valve checked. start by pulling codes . do a ecu scan for codes then u will have a better idea of whats wrong. bad O2 sensors will run like crap, but i bet if u have no codes its a plugged up cat!! this causes backfires and will make it have no power and run like crap and die. my firebird was doing that till i gutted the cat
also plugged injectors are something to consider
86GT 93LX is offline
Old 07-17-2007, 06:54 AM
86GT 93LX
86GT 93LX's Avatar
i have my money on plugged up cats
Old 07-17-2007, 08:52 AM
orange_crush
orange_crush is offline
Granatelli Sales
The New S550 2015-2020 Mustang
21
04-27-2017 02:33 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 09:22 PM
v8sn95
09-07-2015 11:17 AM
Luke9222
09-04-2015 07:46 AM
cbird1177711
09-02-2015 09:51 PM
Quick Reply: HELP 86 STANG WON'T RUN
Featured Sponsors
