quadrant and firewall adjuster. which kind?
RE: quadrant and firewall adjuster. which kind?
I'm looking at the Maximum Motorsports kit. Thier website goes into detail about how thiers is engineered better. They also say that the OEM cable is by far the strongest. You can find them on eBay for $67.00.
I just bought and installed the UPR kit I got off Ebay for $70 shipped. Triple hook quadrant, Firewall adjuster, and adjustable cable. The cable didn't look any beefer than the stock one and the stock one isn't adustable. The only problem I had was removing the upper plastic piece from the top pin. It's the upper triangle with teeth. There isn't enough room to slide it off the pin. There is part of the dash bracing in the way. So what I did was lay a big brick on the clutch pedal to hold it to the floor (after everything was removed, cable, big plastic quadrant part) so it raised the part that need to come off up to the hole in the fire wall ( where your new firewall adjuster goes). Then I went from outside in the engine bay and used a long screw driver and hammed to split the plastic part and get it off the pin. The rest of the install was a breeze.
The clutch pedal action is so much better now. No more trying to Fred Flintstone the clutch pedal to the floor to get it to engage.
jwog666
12-27-2021 08:09 PM
treesloth
09-28-2015 07:03 AM
mrappe
09-26-2015 10:16 AM
