second gear problems
I have been having problems with my second gear. Sometimes when I shift to second it pops out of gear. It does the same thing downshifting. I think I may have to readjust my shifter throw but what does this mean?
RE: second gear problems
Mine was doing that with everything stock.I didn't pay to much mind to it till it shattered 2nd gear into peices.I used to go from 1st to 3rd till I tried 2nd one day and it just about locked the car up.I felt a big clunk then heard peice flopping in the trans.
ORIGINAL: mustang8719
if its a shifter problem it should do it in 2nd, 4th, and Reverse. Does you have an aftermarket shifter with adjustable stops? If you have a stock shifter it sounds like u got internal tranny problems. Adjust the stops if you have them. Good Luck. If you dont, I would suggest gettin a shifter with adjustble stops so you can jerk the hell out of it and not worry about it as much.
