My belt keeps doin a really loud squeel whenever I rev it up. The wierd thing is that I lubed my belt and I know thats not the problem. I was thinkin the belt might be too tight. Would that cause this and how can I fix it? thanks
I had the same problem and I found out that the belt was to big and the arrow on the tensioner wasn't in the "range" area. So you might need a new belt. I hope that helps!!
Well the belt bypasses the power steering and the smog. The tensioner is all the way down, if that makes any sense. Is that a sign that the belt is too big.
Yes!! The tensioner has a arrow on it which is supposed to be in the"range" area and not all the way down. In other words your belt is to big. I hope I explained it o.k.--if not maybe someone else can explain it to you better. Good luck!
