WHAT CAM SHOULD I USE?
Old 07-18-2007, 09:41 AM
GA_MUSTANG
GA_MUSTANG's Avatar
Default WHAT CAM SHOULD I USE?
WHAT CAM SHOULD I USE IN MY CAR-IM NOT ABLE TO BUY THE HEADS I WANT RIGHT NOW BUT I HAVE THE ENGINE ALREADY OUT SO A CAM WOULD BE THE CHEAPIST UPGRADE FOR ME RIGHT NOW--ILL BE USING THE STOCK E7'S - GT40 INTAKES -65 MM T/BODY
THANKS
GA_MUSTANG is offline
Old 07-18-2007, 09:44 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: WHAT CAM SHOULD I USE?
depends on what heads and intake you'll be using in the future. if it'll be naturally aspirated then steeda offers some good cams #18 cam or for supercharged #19 not many people here like the ford cams but they are a choice[&:] or a place called camshaft innovations offers good choices
mjr46 is offline
Old 07-18-2007, 09:48 AM
331StrokerFox
I ♥ Acer
331StrokerFox's Avatar
A cam is not worth it other than sound wise if you are running factory heads.
331StrokerFox is offline
Old 07-18-2007, 09:53 AM
mjr46
mjr46's Avatar
Ain't that the f'in truth!!! I changed out my stock cam and put an f-cam in and had a set of stock ported heads sitting around so I put them all on at the same time and the damn car still runs 13.80's at 98 mph!!!! but the car sounds better now with a choppy idle sweeeeeeeeeeeeetttttt!!!!!!![:'(]
mjr46 is offline
Old 07-18-2007, 09:56 AM
GA_MUSTANG
GA_MUSTANG's Avatar
YEAH I WANT TO SAVE UP AND GET A GOOD SET OF AFR HEADS BUT I DONT HAVE THAT TYPE OF MONEY LAID AROUND-SO I FIGURED GO AHEAD A REPLACE THE CAM AND HEADS WILL BE MY NEXT UPGRADE
Old 07-18-2007, 09:58 AM
FivePointOhh
in limbo
FivePointOhh's Avatar
ORIGINAL: GA_MUSTANG
you should really save up your money for a caps lock key
FivePointOhh is offline
Old 07-18-2007, 10:23 AM
WhiteWindsor
WhiteWindsor's Avatar
GA, everyone is right about needing heads with the cam. But a cam will make it sound better. I do have a brand new still in box f-cam that i bought from summit. Never has been taken out of wrapper. I decided to go351 and never used it. If interested pm me with number and maybe we can work out a price for it.
WhiteWindsor is offline
Old 07-18-2007, 10:35 AM
AdderMk2
Banned
AdderMk2's Avatar
www.tristatecylinderhead.com they sell worked GT-40P's... 300hp capable with a competent installer and tuner.
AdderMk2 is offline
Old 07-18-2007, 10:46 AM
331StrokerFox
I ♥ Acer
Forget the cam in the car now...it actaully is a fairly decent cam. The heads are very important. The GT-40P heads are decent but you have to make sure the manifolds will bolt up to them. Lots of times you need new headers (http://www.mustangsandmore.com/ubb/F...ML/000141.html). Save up and buy some nice Trickflow heads.
Old 07-18-2007, 11:12 AM
FivePointOhh
in limbo
ORIGINAL: 331StrokerFox
do some research, there isbetter for the money....fo shizzle
Quick Reply: WHAT CAM SHOULD I USE?
