I would like everyones expertise on this one.
#21
RE: I would like everyones expertise on this one.
ORIGINAL: Mustangkiler
Well when i look at the tw head it says 66cc exhaust runner so shouldnt that be in cubic centimeters measuring the entire volume of the whole runner inside and so then wouldnt the dart with a 75cc be bigger in volume and have better flow?Or are you just refering too the fact that one could hold more cc's but the runner may be longer and that would give it better exhaust flow?
Now obviously that example is really exaggerated, but it's the same theory. IF the TFS runner were extended to be the same length or the Dart runner were shortened, which would be larger? Which would flow more air? There is an equation to figure out the differences but you'd need a lot of measurements not provided. In reality, they probably flow extremely comparable. I would NOT base any decision of which would be a better head simply because of the difference in runner size. And honestly, if I were guessing, I think the TFS will win. I'm fairly confident it would win on the intake side.
For your application, IMO, your best buy (assuming you won't be buying a custom cam initially), are the TW heads. IF you were buying a custom cam initially, there are probably 2-3 others I'd consider.
#22
No sir, not yet. I'm going to take the car to US 41 Dragway. That will do
me fine. That will also tell me if my TwEECer tuning skills are up to par.
The best way for me (IMO) to know how fast my car is . Is to take it
to the track not the treadmill.
#23
Thanks, Ya well all of this could be a mute subject ifI get my buddies heads and cam real cheap. Other then that I will probably just do some more research on flow charts and results of dart and trickflow heads on supercharged mustangs likeI have already.
#24
Except for the fact that the header bolt pattern is completely different and it still wouldnt bolt up to my intake at all which i cant change because i have to have the gt40 with my kb.
-P.
#25
I told you about that old timer at the Machine Shop....he said that Darts are HORRIBLE!
And he does not sell heads either...so it is not like he was trying to sell me something....he was generally giving me his honest (professional) opinion...
If you want to stay away from AFRs, Ivote TrickFlow
#26
Man your splitting pea's with all the technical crap on the heads, just get the trick flows if you don't want the afr's and call it a day. so what if one set produces 3 more hp than one set. there's no one perfect combo. I got freinds running trick flows that are faster then ones running afr's. if your trying to build a 9 sec car then maybe I'd worry but if all you want is a 11 or 12 sec car it doesn't matter but I wouldn't use darts they work good on a chevy!
#27
How are they actually measured then FullAuto? Onyx i could be in the nines for compression even with the 58 chambers, but it still doesnt mean its a good idea to use either one on a boosted engine.
#28
Wierd reason? Being able to run more boost and make more power and make it safer doesnt sound too wierd too me. There is a reason why the best boost compression is 8.5 to 1, sure you can use those afrs but you cant run much boost at all and if you try too you will just have to retard timing to keep it from detonating and will belosing power. A car with 10 lbs of boost on 9 to 1 compression will always make more power than a high 9.7 to 1 because of all the timing you need to take out.
#29
ORIGINAL: CantStopTheFox...
That's not saying he isn't good at what he does. But he's probably been doing the same thing for 30 - 40 years. And doing it the same way day in and day out. I'm sure his way works great. But the fact is, times have changed and technology has changed. And it's probably safe to say that he did not change with the times.
Reminds me of Grandpa Simpson when he was talking about people changing to the metric system. His response: “The metric system is the tool of the devil! My car gets forty rods to the hogshead, and that's the way I like it!”
#30
i've heard mention of canfields in here but nobody seems to be latching on to that one.
thats the route i'd probably be taking. hell there's always the victor jr. heads which are alot better than most people would think
