Idling problem
Old 11-22-2007, 03:10 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: Idling problem
sorry to bring up a really old issue but this is what im dealing with now is a crappy idle when the motor is cold.
so if i unplug the iac and it makes no difference does that mean its bad? how do i check the map sensor and how does that effect idle when its cold? little more input would be great if you could, thanks!
FivePointOhh is offline
Old 11-22-2007, 08:45 PM
89mustangfive0
89mustangfive0's Avatar
is your car converted to mass air? if it is you aint got a map sensor.i had the same problem wit the idle as you, i changed my iac, cleaned mass air sensor, new tps at .98 changed the coolant temp sensor and it got better but it started idleing like crap untill some guy at the gas station made me pop my hood he touched the 2 10 pin connectors ( salt and pepper connecotrson the back of the intake) and the car idled mint. just move them around and see if the idle gets better
89mustangfive0 is offline
2007CalSpec
12-13-2020 11:42 AM
2007StangV6
01-28-2016 06:09 PM
96stang3.8
09-10-2015 06:42 AM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Idling problem
