Compression Numbers
RE: Compression Numbers
Holy cow manure!!!!! I found the reciept!!! it was the third one I pulled out of the bag!!! what luck anyway here 's the part# ARP-134-7104 THESE are longer then standard length but you'll have to measure yours and compare the length sizes but you can order these through summit they cost about 35.00
the eddy rpm 2 has a baffle the goes on the bottom of the lower to stop the oil.
i pulled the head and found a blown head gasket right inbetween the two middle cyl's and on the side of #1
im gonna see what the other side looks like tomorrow, then pull the crank and see what the main bearings look like.
ORIGINAL: 94StinkinLincoln
kolysrock@hotmail.com
Thanks
09-23-2015 01:28 PM
uberstang1
09-20-2015 06:42 PM
