Flex-a-Lite VSC
Has anyone had experience with the Flex-a-Lite Variable Speed Control? I want to use it when I install my Taurus fan inplace of using a regular fan setup that uses a 30 amp relay and is at a preset temp. I know www.dccontrol.com is probably the best way to go but Im not sure I wanna wait that long to get all this stuff installed. I guess Im just wondering if the Taurus fan will put to much of a load on the VSC and burn it out since most people say they upgrade to a 75 amp relay when installing a Taurus fan.
VSC link http://www.jegs.com/webapp/wcs/store...52453_-1_11471 |
RE: Flex-a-Lite VSC
I went with dcc, I have to wait 4 weeks but it will be worth it. It is built with quality and that is why they take some time to make. I also like how the dcc slowly throttles the fan up and only goes as fast as it needs when cooling... No extra relays needed as well.
RE: Flex-a-Lite VSC
It seems like the VSC does something like that starting at 60% and ramping up to 100% as needed, and the soft start feature. Which model DCC did you go with? I was kinda weary about using the 35 amp one since people say the taurus fan draws allot when it first kicks on. Id go with a DCC BUT I wanna get all this stuff put on in the next week or so ( waiting on my 3g alt from Adder ) can hit the drags up again, my stock fan clutch is locked up and the fan is starting to come apart on me.
