Help with 1990 5.0 door seal leak
Old 07-19-2007, 08:53 PM
lostinhisown
lostinhisown's Avatar
Default Help with 1990 5.0 door seal leak
Hello Mustang owners,
I have a problem i have been dealing with and cannot find an answer to so maybe you can help. I have a 1990 fox body 5.0 and i recently replaced the right and left side door seal because it was leaking and was torn. Now that it has been replaced it still leaks maybe even more than before, and i am about ready to just pay to have it done before damage to the interior sets in. My question to you guys is one has anybody else ever expirenced this same issue? Two is there a special method i didnt follow when installing the new parts that may have caused this? And finally could this problem have been avoided by maybe buying OEM parts rather than non-OEM parts?
lostinhisown is offline
Old 07-19-2007, 09:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Help with 1990 5.0 door seal leak
run a garden hose over the roof of the car and look for the leaks make sure the top of the window frame isn't bent out if so grab it and bend it back in a little I did that to mine now all is good I bought my seals from 50resto.com they seemed to work good. just don"t go down to napa and get what apeared to be the same size[:'(]
mjr46 is offline
Old 07-19-2007, 09:06 PM
creekrat
creekrat's Avatar
hatch, notch, vert? What are we talking here? Are your doors closing properly? hinge pins ok? glass adjusted?
creekrat is offline
Old 07-19-2007, 10:07 PM
stang8689
stang8689's Avatar
O.K
1. Probably aftermarket seal, not as good as factory.
2. Its best to put a dollar bill on the seal and close the door. It should have a good resistance. If not open the door with the window down and grab bottom of window frame and top and bend in.
3. Its not on common for the striker to be worn and not hold door tightly close, also check hinge bushings, even though it won't cause a leak.
4. Could have a leak between door glass and frame.
stang8689 is offline
Old 07-20-2007, 06:42 PM
lostinhisown
thanks for the reply ill check it out and see i really appreciate it
matthew
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
Demodulates
09-18-2015 11:14 AM
MusicCity615
09-12-2015 07:05 AM
Quick Reply: Help with 1990 5.0 door seal leak
