Trottle body size...?
#21
RE: Trottle body size...?
ORIGINAL: lecznar1
i'd do the 65mm throttle body(or 70 depending on what u plan on adding to the motor) and dude don't even bother getting the bbk h pipe.... just get the summit one, it's cheaper and it's pretty much the same thing... all it is is metal tubing so it doesn't really matter
does anyone know if like....jeggs does the same thing? i know summit brand stuff isnt always another brand that is any good.
#23
i am putting a 75mm throttle body on the engine that i am building. i am porting the inake and the heads i have a hydraulic cam and lifters 1.6 rocker armsi am thinking about putting different pistons in it to up the compression ratio does nebody know what the stock compression is on a 89 H.O. do u think the 75 mm will be to much cause my plans are to later put a supercharger in once i get moe money saved up. ne feed back would be nice
