water pump
water pump
i i was going to replace my water pump and i ended up snapping off 1 of the bolts on the ac/ps bracket and now there are 2 bolts that dont want to budge and feel like they are going to snap. what should i do?
RE: water pump
you could try heating lightly but not to much because those covers are cast aluminum. otherwise put a bigger bar on them and flex like ARNOLD would and snap'em off!! then drill and helicoil new holes. if your good at it and pick the right size drill bit after they break all you'll need is a tap to rethread the hole.
jwog666
12-27-2021 08:09 PM
