NEED some help deciding!
RE: NEED some help deciding!
cfi is not carbed fuel injection, it means central fuel injection which is basically tbi, I quess. It is a throttle body w/ 2 injectors mounted vertically in the throttle body, it is then mounted on a 2 barrel manifold
so Vfast there is and isnt carb fuel injection, lol
ORIGINAL: vfast
carb fuel injection? please thier is no such thing there is carb fuel injection and a cross of the 2, TBI= throttle body injection
On to my last question would placing a fuel regulator between the fuel pumps burn the pumps out. I just found out that the CFI (central fuel injection) regulates the fuel pressure to 39 psi, im thinking a problem will occur if i place a regulator in place
i know people who have used the stock (in tank) electric pump and just used a regulator. You may consider pulling the stock fuel pump out of the tank and using a small auxillary electric pump. you can get these from your local parts store for like $30. If the in tank pump goes bad, you will have to do this anyway if the stock pump goes bad and thats only a matter of time if its been pumping fuel since 85. I say definetley go carb., just tune it right and it will be fine. Good Luck
ORIGINAL: ho85GT
best solution is probably to get a fuel pump made for carbs and re-plumb the whole fuel system including the supply line to the pump which should be a gravity flow to the pump inlet.
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
