Fuel Preasure
RE: Fuel Preasure
I would not waste my money on an adjustable fuel pressure regulator. You don't need one. Any tuning should be done via the EEC. Save your money and put it towards a Tweecer RT. BTW, the stock fuel pressure (stock FP regulator installed) on my car is ~47 psi without the vacuum attached to the regulator and 40 psi with the vacuum attached.Pressure with the vacuum attached will vary due to the vacuum that theengine produces at idle (different levels based on displacement and cam used). Hope this helps.
Rick
Rick
mrappe
09-26-2015 10:16 AM
