Who runs a 347?
Who runs a 347?
Okay i'm trying to get ideas on what kit to choose and how to build a 347 myself. I think I will be using my stock 128k 302 block and just clean it up and do all of the maitenence on it. Whats the best company that makes the best reliable stroker kits? Should I bother with building mine into this or should I just get a 351W or Cleveland? In the end I want to make 400-500 hp/trq and still be able to drive it around town if I wanted. So if any of you have built one of these engines, leave me some tips and advice on how to do it right and what parts are crucial to have. Also what your mods to yours are and how much power you are making. Thanks alot
RE: Who runs a 347?
Buddy of mine just got a short block from this guy
http://cgi.ebay.com/ebaymotors/STROK...mZ190133275723
Then put a custom cam and Canfield head package from
www.camshaftinnovations.com on there for another $2,000
Call and talk to both companies before ordering to confirm compatability as far
as notched pistons and piston dish size for wanted compression level. 10.5 - 11 is good.
That combo with following parts will make 450-500 flywheel hp all day long and run like a champ on streets.
You will need upper end intake like Holley Sys II or Trickflow R or Edlebrk Vic 5.0
and 1 3/4 longtube headers.
Trans and clutch will need to be upgraded eventually too.
RE: Who runs a 347?
I got mine from Brian at AD Performance. Sells Scat kits for a reasonable price. Very helpful also.
Make sure you take the block to a machine shop to get the work done that way you know it is clearanced right.
I just got my stroker running so I haven't ran it hard yet. But I love it so far, idles great drives pretty well, I really need a tune to get the driveablity right.
RE: Who runs a 347?
R.Barn- i see you run a 351, would it be easier and better if I just bought a Cleveland or Windsor block and built that up so eventually I could stroke that to a 393 or 408? Give me the pros and cons on the 351 if any
Also why not use my stock block? Ive heard it is better because it has been through various heat levels therefore being stronger.
I'm just trying to figure out what is the cheapest and easiest way to N/A get 400-500rwhp.
I want to be afraid to boost it... hahaha
RE: Who runs a 347?
'91 Mustang GT
347 Stroker, 185s, FTI Custom Cam, Home ported GT-40E Intake, 30#, 75mm BBK TB, 77mm Pro-M MAF, JLT Cold Air, Underdrive Pulleys, BBK LT Headers and Catted X-Pipe, 2 Chamber Flowmasters, Aluminum Radiator with Black Magic Fan
(in reply to r.barn)
[Send Private Message] Report | Post #: 4
RE: Who runs a 347? - 7/24/2007 6:35:32 PM
New Messages
93Mustang5.0
Status: online R.Barn- i see you run a 351, would it be easier and better if I just bought a Cleveland or Windsor block and built that up so eventually I could stroke that to a 393 or 408? Give me the pros and cons on the 351 if any
ORIGINAL: 93Mustang5.0
RE: Who runs a 347?
I say boost it and call it a day.
Don't forget your fuel system if you go that route.
A 351 would make it easier to get to 400-500 but still not cheap.
Disadvantage - Price and Weight otherwise...its better
RE: Who runs a 347?
while relatively easy to do there are still headaches and draw backs to the swap
It weighs more and has hood clearance probs, but is stronger engine all around.
If you only want 400rwhp (about 500hp) then just build up a stout 347 with a small
shot of nitrous for the weekends and have half the headaches of putting a 351W in there.
or you can just turbo a slightly upgrade stock engine and hit 400+rwhp.
There are about 50 ways to skin this cat
Its just easier to order another block already done up. It's not more expensive
and you now have a spare block to set aside.
If you want to get insane, drop a 351W in there and turbo it later like I am
Terminate some Terminators
RE: Who runs a 347?
ORIGINAL: r.barn
351W is better for hp over 500rwhp, which is what I wanted.
