Melting #5 Plug with Nitrous????
I put a Zex nitrous kit in my stang last weekend. On monday I got the bottle filled and decided to make a test run on the way to work. It ran fine and the air/fuel was right between stoichiometric and rich. Afterwords, it was missing and running like ****. I pulled the plugs, and the number 5 electrode was melted over onto the center of the plug. Every other one looked perfect. I got a diffent plug, and tried that. It still ran like crap. Last night, I got a new injector for it, and did a cylinder pressure test. I also pulled the valve cover and checked the pushrods and rockers. The cylinder had about 140 psi pressure, and so did the rest, relatively. I put it all back together, and it ran great. No miss, hesitation, or popping.Today Idrove it withoutnitrouswith the timing at 17* and itran great. When I got home, Iset the timing to 4* and tried the nitrous again. Same thing- it burned the heck out of that one plug. I'm running a 150 shot on a wet kit. The heads are off a 69, and the autolite 25's are the coldest they go (1 range colder) without going to a plug with a shorter depth. Even with those plugs though, I still should see the problem with all cylinders if it was a timing issue.
Any ideas???? |
RE: Melting #5 Plug with Nitrous????
pop the dizzy cap off.
i bet the terminal for that wire is gone. |
Nope- the terminal is still there. I'm about positive its getting spark, but for some reason its running way too lean.
Actually you can step down to an autolite 24, the 25 is stock.
yah i can see its running a tad lean, lol
well, 150 wet shot shouldn't do that, unless the "wet" aspect wasn't functioning properly. you need at least a 155lph pump to run that shot. what you running? |
The pump is stock. Zex never says anything about needing a bigger pump, but it would definately be a possibility. Any idea why it would only do it on one cylinder though?
Also, ditch that narrowband POS and get a wideband. All that it is going to tell you is if you're running 14.7:1 AFR, above or below that. No real numbers.
theres a few different reasons for that to happen to only one cylinder.
off the top of my head real quick, you could have a tad higher compression ratio in that cylinder caused by a bit of carbon buildup. timing and lack of fuel will affect that cylinder before any other. |
what if there was a vaccum leak on the lower intake for that runner?
yup that would do it too.
he would most likely be able to feel that though. |
