overheating
overheating
hey my 84 gt is overheating and I cant figure why. daily driving its fine up to 2700rpm but if I wonna hit and go 4-5k rpm it overheats really fast. like in less than a minute the needle redlines. I drained the coolant and put a strong mixture in 65/35 and I am using good full sny oil and there are no leaks anywhere.
HELP !?!?!?!?[:@][:@]
thanks
thanks
RE: overheating
ORIGINAL: 84gtcustom
thanks
thanks
RE: overheating
Sounds like the car is pre-det! If you have no leaks and it only does it when you get on it! Check your timing, check all the plugs to make sure they are gapped correctly. What kind of fuel are you using? Reg or premium? Check fuel pressure! Could be a fuel pump going bad. But I would start with the fuel and timing. Could also be a plugged fuel filter!
RE: overheating
no I dont have to add any fluids
no there is not any white smoke coming from the exhaust but it does smell extra funny
plugs and all just got replaced so there all good
I am using reg fuel - what would the fuel pressure/ pumpmake any diff - just curious
I'll check the comp and get back to ya'll
thanks
thanks
RE: overheating
looks like we have the same problem hope we can find some info on this I am stumped. hears the thread I just made earlyer today.
https://mustangforums.com/m_3609248/...tm.htm#3609452
mungodrums
09-29-2015 09:18 PM
yourmom6990
09-14-2015 10:52 PM
