3.73's Installed!
So Im finally at the gear stage and just installed 3.73's today and I am very veryimpressed in the difference there is in the car. My question is what is the spedo reading difference with my 3.73's vs. my stock?
RE: 3.73's Installed!
I hope mine are going in this they have been in the garage for a month sitting in the box. are you going to do any suspension work
My suspension is done, its Napa and Ive got the adjustable rate springs, and they work awesome. The rear sags good on the launch.
check your door tag, "ax" m=2.73 z=3.08 e=3.27 for original
you'll be about 15-20% off right now check http://www.ddperformance.com for a speedo calc or guide |
I had 2.73's for stock. And thanx for the site.
ok...you'll see there what you need, my first fox was '90 gt same color.....but an anchor...er...i mean aod
sorry didn't know better then....it was 1990 lol |
Haha ya i know its a aod, but my fist stang, so im loven it. How much more do you like a 5 spd or an oad?
bro......it's night and day
here ya go....best times from all my cars w/mods 1990 gt aod ** 3.73, dynomax catback 2.5", gt40 intake, sprotsman pros, 1 5/8" shorties, ud pullies ------- 14.10 1989 notch 5-speed ** 4.10 , mac long tubes, flows catback, o/r h-pipe cai, et streets , 75 shot NOS dry --- 13.28 NA / 12.50 juiced 1988 notch 5-speed ** 2.73 gears 100% bone stock on street tires (120k on motor) -------------- 14.20's 1990 lx'vert aod ** 3.73, summit catback, 100 shot zex dry kit street tires--------------------------15.10 NA / 13.60 juiced 1993 notch 5-speed ** 4.10 , mac lt's, mac catback, mac prochamber, et street radials (w/ fuel issue)-14.00 NA/ 13.00 juiced now the current car is times b4 dumping about 75 lbs, and fixing some vac leaks. i expect it to run just like the '89, it 60's better than the '89, but doesn't ET like it we'll see aod has a 1st gear of 2.40....t5 is 3.35 and it only begins there...i'm not dogging the aod, i tried to make it work, i went through 3 on my '90 GT and finally gave up, even got another aod car after that so wtf but when it boils down to it.....it's a 5.0 and it's fun as he!! so be happy w/ it nothing catches an eye much more than a red GT |
** EDIT**
'90 gt best time was 14.40 and i forgot , even w/ 2200 stall, and motorsport lowgear set which bumps 1st from 2.40-2.84 and 2nd from 1.47 -1.55 + better od band it still ran 14.40's that kit is basically the upgraded parts from an aod-e from a lincoln mark 8 |
Hey man thanks for the info and ya your right i do get a lot of looks.
| All times are GMT -5. The time now is 12:40 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
