Switching 19lb to 24lb injectors
What up what up...
Question check my mods below, I currently have 19lb injectors how much of a difference will you think I will get fo feel hp wise switching to 24lb? And I heard that you have to tune the comp also to get the most out of that, I currectly have an a9l comp which is for the most part really adaptable to any new part, I will also me adding the 24lb MAF just wondering what the difference will be. I'm sure i'm running lean .... Let me know your thoughts thanks
RE: Switching 19lb to 24lb injectors
No hp gain. you're probably not running lean.
go spend $70 on a couple of Air Fuel ratio dyno pulls to see what your A/F really is
before dumping $500 in new injectors and MAF you probably dont need.
So you guys dont think a car with h/c/i really needs 24# injectors?
I have a set Im putting on this week along with a 255 lph fuel pump and 75mm MAF.
My car will have AFR 165 heads, a custom ground Comp cam and an Edelbrock Performer intake and some other bolt ons.
ya youbur will see a power difference with the set up u have but you should get you maf sensor calibrated for the 24 lb injectors or go the better way and go carburated not alot of tuning un stupid electrical b/s and if you dial it in right its just like fuel injected
ORIGINAL: pbguns
