having a crappy weak
so in one week my alt. goes bad rear window shatered and leaking coolant.....so my car was running hot so i look under the car see it leaking under the water pump so i buy one and isstall it took it for a drive getting hot again so i look under the car and its leaking again in da same place with the new pump so what could be the cause should i c if the thermostat opens up could that cause the coolant to flow opposite way and comeout the peep hole??? helpppp
RE: having a crappy weak
sorry for misspelling week
can anyone help!!!
plzzz help
Nobody knows!!!!!!
Give people some time to answer, maybe you did not clean the surfaces real well or your new water pump was bad to start with.
If you bought a cheap ass autozone reman take da' poop back and but a new one I put a reman on because it was 25.00 vs. 60.00 and had to redo it 3 days later because it was pissing out the weep hole
ORIGINAL: carsurplus sorry for misspelling week Keep this link handy. http://www.m-w.com/ Without a doubt, you need to take care of any leaks but minor seepage out the weep hole will not make a car overheat. Good chance your problem is elsewhere. Check the radiator, thermostat, fan, etc. What conditions does it take to make it overheat. Does it run hot on the highway, idling, when? |
more than likely a bad pump, you probably disturbed the timing cover gasket when you took the pump off, you probably didnt burp the cooling system properly.
try again, and take you time, do it right |
it was poring out from under the water pump
