Light bolt-on upgrades
I just bought my first mustang about a week ago and it has a MAC cold air intake and a Flowmaster exaust, just starting to look for some bolt-on upgrades that would help the HP out a little, anything would be great, alsoany sugestions on shocks and springs for it,it is a 94 GT convertible. Thanks
RE: Light bolt-on upgrades
i am saving for a supercharger but that is going to take some time, i am mostly looking for things that will be good for some power and will also take the power of a supercharger in the future(when i get the money saved up), i am intrested in heads and an intake any sugestions what would work good together and the budget for now is withing a 1000 bucks or so but sugestions would help for future purcheses also. Thanks
if you get gears you want a place to install them unless your very tech savy. should run ya 400-700 installed.
if you want heads and intake for under 1k. gt-40 (non-p) and typhoon intake or gt-40 intake. i reccomend typhoon because it can be worked later for bigger gains. i'm getting RHS heads, very good and very cheap compared to most. might wanna save and get a good set of heads. dont forget all supporting mods, its gonna nickle and dime you to death!
go for some gears right now
my car right now is stock but im not to sure on what to do. i have been thinking about gears. what is the gear ratio on a 94 GT stock? 2.5* something like that? im not too sure
ORIGINAL: droptopred
where would be a good place to purchase gears, also are they hard to install?
Also, if you want a free mod, advance your base timing. There's a good atricle in the Tech sticky at the top of this forum. You can advance it from your base timing of 10 degrees BTDC to about 16 degrees BTDC. That will net you some free HP / TQ and will give you better throttle response. BUT if you do that, you will ahve to run a higher octane fuel.
