Stock Heads
RE: Stock Heads
LOL!!. I had sum gt40s but i have the flat top pistons so im kinda limited. unless i change the pistons. which i really cant afford right now.
i need the dual springs fir the cam i bought.Thanks-Shaun
RE: Stock Heads
dont even install that cam until you get your head situation figured out. you will lose alot of power all around. you should only install a bigger cam when your heads are outflowing your cam, if you do it the other way around you will not be happy! the stock cam is not a bad cam and ive seen it support around 300hp easily,e7 heads on the other hand.......................
RE: Stock Heads
Fivepoint; Time to get out the tool catalog. There is a cutter you can buy frome Crane that come with the arbor that you put in a 1/2" drill and then do them yourself at home.
I've had one for years...
Works good...
I don't think the thing would cost $60 even nowadays.........
I sort of wonder why you need that much cam also....
Works good...
RE: Stock Heads
are you guys sure 1.84 valves from a pair of gt40's would even hit flattops with a .512 lift cam? even if they are the ones without vavle reliefs i would mock up the motor and see what you get.... i'd like to think its possible
