Need help with MM Adj RLCA's
Old 08-04-2007, 08:54 PM
kcsoa22
kcsoa22's Avatar
Default RE: Need help with MM Adj RLCA's
Adj uppers do adj pinion angle, I am talking about lowers
From MM's Website
Heavy Duty Adjustable Rear Lower Control Arms, with Swaybar Mount, 1979-98
The easy adjustment of MM's Adjustable Control Arms allows raising the rear ride height by up to 2 inches, or lowering it as much as 1 inch. A heavy-duty weight-jack bolt, similar to those used in NASCAR, makes this possible. The spring perch design allows easy ride height changes, with the car still on the ground. Road racers and autocrossers can set not only the ride height, but also corner weights, for optimum handling. A car can be fully loaded up with gear for a road trip, and then have the rear ride height adjusted back up to normal, to avoid bottoming out. These control arms are available with mounts for a factory-style rear swaybar, or without any swaybar mounts, for use with MM's Adjustable Rear Swaybar.
kcsoa22 is offline
Old 08-05-2007, 09:08 AM
5.0stanger
5.0stanger's Avatar
just wanted to say, you car looks 100% better lowered and with the bullets [sm=hail.gif]
5.0stanger is offline
Old 08-05-2007, 09:34 AM
ACE
ACE's Avatar
I dunno I have them on my notch and I raised them with the weight off of them. Make sure that both the pigtails are pointing to the drivers side.
ACE is offline
Old 08-05-2007, 09:42 AM
kcsoa22
kcsoa22's Avatar
ORIGINAL: 5.0stanger
Thanks, I appreciate it. I am very pleased with the outcome
kcsoa22 is offline
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
GimpyHSHS
09-18-2015 12:27 PM
LMPerformance
01-20-2005 01:42 PM
Quick Reply: Need help with MM Adj RLCA's
