FMU question (getting rdy to install s/c)
i just wanted to make sure i dont need to install the FMU if i am installing 42#ers... also if i have an intake fuel pump do i need the inline pump... should i just intall it for xtra protection or should i leave it off??
RE: FMU question (getting rdy to install s/c)
I would reccomend installing the FMU as long as it has the disc in it for the 42 lb injectors, if it's got the disc for 24's it's going to try and push way too much fuel. Install the inline pump! Don't even drive the car with out either one of those things installed, it's just asking for trouble. You can ditch the FMU if/when you get your car tuned. Are you putting a 255lph in tank fuel pump in also?
ORIGINAL: 92hatchLX
ORIGINAL: luckythirteen13
f*ck the fmu, just go get a dyno tune
ORIGINAL: PRO50SC
Agree. And put the additional pump on too. Then get your tune when your done installing everything.
ORIGINAL: PRO50SC
p-1sc, 12#'s, 368/406 stock block heads and cam.
Shifty Magoo
08-25-2015 03:08 PM
Soldier GT
08-12-2015 03:46 PM
